by Follicly Challenged » 25 Aug 2005 16:43
Just my Opinions
Insufficient Valve spring pressure or rate per inch, is a surefire way to bounce the valves on the seat.
This can manifest itself with many seemingly weird valvetrain symptoms, not the least of which is to eventually "knock the heads off the valves", even 1 pc. SS good stuff. Get the correct springs for the profile.
Yep, most hughes stuff needs their springs, or rather a rate per inch conduscive for that profile. They grind their stuff with a little faster ramps to whack the valve open and closed quicker "because they can" with the mopar .904 lifter dia.
Best stay away from the stuff asking for 150 # seat pressure though as it don't live great on a street driven year after year type deal. Stay with the grinds requiring around 120 # on the seat.
SS HEMI guys used to play with slightly less than adequate spring pressure, to actually get the lifter to leave the cam at the top @ rpm to cheat more lift and beat the old lift rules(more lift) and make more power, called "ramping" the lifter, don't YOU do it.
I.M.H.O. "ditch the 5 spd idea". You're gonna need both hands on the wheel to keep the thing on the road, LOL, seriously though, trying to powershift a std @ 600 hp just ain't reccomended if you're using the stock 2 bolt main block.
The stock blocks ain't happy much past 600 anyway.
If using the cross bolted mega-block, forget the above.
The crank flex torsionally even on a 4340 (non-twist??)forging ain't great for the stock #4 main cap, even for a split second while the clutch is disengaged, it's enough to start the hammering and it's not "if" but "rather "when" it exits stage bottom.
Do the automatic and maintain the crank load on #5 main(the fulcrum) so #4 don't take a beat'in.
If building for a blower, then do just that ! Pistons, C.Ratio, etc., and wider lobe separation cam, 110 ? 112? and correctly timed events for blower. Give B.D.S. (blower Drive Service, California) a call, they have excellent flat tappet solid profiles available, 4500/4600 series are thumpers, ground by ISKY for B.D.S., they are some of best bar-none !
Blower Pistons; If using EDDY's W/quench side, call J.E. Tech, inquire if they build a "keithcraft" Ford type "concave" reverse dome configuration Piston for a BB Mopar, or if they'd build it ? Thats proven to be a "hitter" on blower deals of late, no reason it shouldn't work on the Mopar as well.
Hope I ain't bummed 'ya out, just my opinions.
