I've had my 70 Challenger for about 6 years now, and it's been sitting in my various garages the whole time. I am now ready to semi resto/customize this car now starting with a full paint strip to metal and yanking out the 440 and rebuilding it.
I need advice on a hot street 440 build up. I'm going to throw out some items/desires and see what you guys think.
These are some of the directions I wanted to go, totally open to critisism as I have never built an old muscle car era engine.
I plan on using an Edlebrock RPM performer intake, unknown 750-800 carb, possibly Holley possible Speed Demon, I plan on buying a set of Edlebrock 84 cc closed chamber heads and using 2.14/1.81 combo valves, As far as compression ration, I will run cat pee California gas (91) but I do have access to a gas station that sells 100 octane at the pump so I was thinking 10:1-10.5:1, should I go higher?
I have been told Keith Black pistons are a good choice, now as far as camshaft is concerned, this is where i'm hung up, I want a good match for the head/intake but I also want a wicked cam idle, I love me some lumpity lump. What camshaft do you guys recommend? I want it on the wild side but not to far out of the range of usefulness, I hoped to use a 2000-2700 RPM stall as this car will be like Tim's car mostly street, but be able to be somewhat of a daily driver/cruiser with reliability and some track time.
Here is a link that is 56K death, broadband required of a 69 Road Runner with a bitchin' sounding 440 and is pretty much the lump sound I am looking for, maybe a little more radical, any trained ears can tell me what this cam sounds like as far as specs? http://www.deadendcruisers.com/videos/datteln2004.wmv
I'm torn between the Hughes cams and Comp cams, leaning more towards Hughes cams. Also I want to use gear drives, does Hughes make a 3 pin cam? Now as far as hydrolic/roller/solid, I am lost, I would probably want to run 1.5 roller rockers for some free horespower.
Does a lumpy idle/street capable/3 pin cam for gear drives exist that can be used with rollers?
I would like to be in the high 12's maybe 11's on juice, I will probably go 3.55/3.73/3.91 out back, here are some pics of the beast before the resto
