by dave-r » 18 Jul 2005 8:28
Could be any number of things. What is the idle speed and mixture set at? Timing? Have you enough stall in the converter?
If it will stall when driving above idle rpm it is most likely carb related (fuel boiling or dirt) or electrical (connections in the coil supply or a bad ignition lead).
