 by Brian » 29 Mar 2001 8:28
			The Edelbrock package is pretty good, but it's closer to the 12.5 sec specs. Keep in mind that the numbers given (417 HP for a 340) are developed with their aluminum heads. It is fairly easy to match the flow characteristics of these heads with your 915's, but not necessarily cheap. But you definitely will need better heads to take advantage of the larger cam and carb.
What I really don't like about the Edelbrock package is the cam. It's a "Chevy grind", meaning that it's the same lobe profile used for their Chevy cams, and that's bad. Not really bad, but not optimal. Mopar lifters are larger in diameter than Ford lifters, which are larger than Chevy lifters. So what? Well, the lifter diameter determines how fast the rate of lift can be without prematurely wearing out the cam. The larger the lifter, the faster the permissible rate of lift. That's one reason why Chrysler was so dominant in drag racing during the factory-sponsored days. You really want a cam that is specially ground for a Chrysler engine. You'll pay more, but it's worth it. Use a Mopar Performance cam if you want to save a little without sacrificing a lot, or go with an Engle for the best performance (these are what Hughes engines sells).
As for compression ratio, a lot depends on the cam profile. The longer duration cams allow (in fact require, to work right) more compression. Notice I specified different compression ratio recommendations for each package. Those are based on the cam selection. You should be able to use premium fuel, with an optimum ignition advance curve and proper carb jetting, without any problems. If you do go with the aluminum heads, you can add at least another half point to those numbers. The aluminum dissipates more heat, and reduces detonation. Of course the 40 pounds or so of weight reduction helps performance, too.
