They closed the last drag track on Long Island (NY) and the next closest track is over 3 hours away and through city traffic. I don't have anything to trailor the car so it's going to be tough to get it out there. I will probably wait till I have more mods to bring it out there (I still want to do a higher stall and exhaust).
Anyway, im really wondering what my 1/4 times would be about. Im not talking about an exact time, but i'd like to know if you guys think this car has what it takes to break into the 12's.
I'll do my best to list everything that is in it. I helped build the engine at a speed shop I work part time at, but my boss picked out most of the parts and I forgot some of the details.
motor:
69 340
balanced rotating assembly
bored .030 over
speed pro pistons (I want to say the car has a 9.5:1 compression but im not sure)
Eagle forged rods
comp exhaust valves, hardened valve seats and valve springs
3 angle valve job
edelbrock performer duel plane manifold
holly 670cfm street avenger carb
hooker super comp long tube headers
MSD 6al
Freddy Brown built 727 tranny with manual valve body/shift kit
3.91 gears
Here are the comp cam specs off the card: intake: gross valve lift: .480 Exhaust: .480
.006 tappet lift : 280
Grind: CRS 280h-10
We recently did a whole suspension overhaul with pst front end rebuild, kyb+lakewood shocks (70/30), weld prostar wheels and Micky Thompson l60's in the rear. The car hooks as if it was all wheel drive. Barely any spin at all when those tires are warm. Of course we are still running the stock stall so that might have something to do with it. It still launches pretty hard for a 340 though. Traction is NOT an issue here.
Most people tell me the car has what it takes to go into the 12's, but they aren't mopar guys.
I've only ran the car at the track once, before they clsoed the track. It was about 85-90 degrees out with VERY high humidity. Something went wrong at the staging lanes and I had to wait. I shut the car off, but when they said they fixed the problem, i turned the car on and the temp was around 210 when I launched. Pretty hot, the car normally runs at 180. I was also only shifting at 5800 when I found now that im getting more power when I shift at around 6000. The launch was also pretty bad because we were still working out some vacuum issues with the brakes. I ran a 14.4 (first and only track run ever), im sorry but I don't recall the mph. That was about a year ago, since then my boss has jetted the carb /swapped springs , which made a HUGE seat of the pants difference.
What do you guys think? Do I have a shot at 12's? Maybe with a higher stall and exhaust system? The current exhaust from the headers back is stock and SHOT. It's rusted to bits and the mufflers have holes galore. I would imagine that is killing some power and the stall isn't allowing it to launch anywhere near 3000rpm-where the came starts making power.
BTW, I am at sea level.
Thanks!
