Are you sure?
I still can use old pistons, because engine is disassembled. I only want to eliminate pinging and but I do not want to loose horse power.
Think that now you are "my mechanic"
I do not want build again the engine and have problemas again.
And about deck distance clearance?
A option : Actual pistons lower comp. distance 2.029",0.053" deck clearance+head gasket 0.039" = 0.092" total deck clearance, 10.34:1 compression, 0.140" dome.
B option : New pistons higher comp. distance 2.065",0.017" d.c.+head gasket 0.039"= 0.056" total d.c., 9.5:1 comp. flat top
What is the real importance of deck distance?
You believe that first option is best?
How many HP could I loose with second option?
Maybe could I use 95 octane fuel with lower comp. pistons?
Any more think to know? Tomorrow I begin to build it again.
Yes , I know, a lot of askings
But really you are the best information i have too much time ago.
Thanks ++++
