Hell. It was 2am here when I replied to that this morning.
I am suprised I could write at all......
OK carbs. Let me expand on this.
A carb lets air and fuel into and engine. The more air and fuel the engine burns the more power you make.
But it is the engine that draws the air/fuel in. So no matter how big or how many the carbs the engine will still only draw in the same amount of air and fuel. Obviously rpm is a factor. The higher the rpm the more carb you need.
The only time you will make more power with more/bigger carbs is if your current 750cfm carb is too small for your engine at high rpm.
However since you say your engine is near stock and probably has a stock or near stock cam I am sure the 750cfm carb will be the ideal size.
You also need to think about the intake manifold. Dual carb manifolds tend not to distribute the air/fuel to all the cylinders very well. Nor do they flow very well.
The manifold you now have is a very good one. It will work well at low rpm and up to 6500rpm. Being a dual plane it will also have quite good throttle response.
So the bottom line is leave the carb and intake alone.
