To tune a carb you need;
a)A Vacuum gauge.
b)A way of telling how rich or lean your engine is.
It is vital to check that the fuel level and pressure is correct before you start!!!
You also need to make sure your ignition timing is correct. The timing is tied into this which can complicate things.
So assuming there is nothing wrong with the engine/carb and the timing is spot on and the idle speed is set to 600rpm (manual gearbox) or 800rpm (auto).
To set the idle mixture turn the mixture screws lean until rpm drops a bit. Then turn rich until you just get max manifold vacuum or max rpm with the car in gear. If the mixture screws do not seem to do anything your engine may have a long duration cam installed so you need to pay attention to the following.
Bigger duration cams might need a higher idle rpm to run smooth.
Unplug the vacuum advance on the dizzy and plug your vacuum gauge into the dizzy timing port on the carb.
This port should get its vacuum source from above the throttle blades (not manifold vacuum).
At idle there should be no vacuum on this port. Big cams demand a lot of air and fuel at idle. So if a bigger cam than stock is in the engine the following steps may need to be taken
If there is vacuum present on the dizzy port it means that the throttle blades are open enough to allow the mains to operate and supply fuel at idle. If the mixture screws cannot give you enough you need to modify the idle circuit so that it can supply enough air and fuel by itself at idle. You may find that the mixture screws do very little anyway until you fix this problem.
On a carb fitted by the factory on a mid 70s+ stock engine you may need to enlarge the idle restriction hole in the metering block very slightly to allow enough fuel into the idle circuits. Aftermarket carbs designed for performance should be OK though.
Some performance carbs have a screw to allow you to adjust open the SECONDARY throttle blades to increase idle speed. This allows you to then close the PRIMARY throttle blades with the idle speed screw until vacuum drops right off at the dizzy port.
You might also need to drill a hole in the PRIMARY throttle blades (start at 1mm) to allow more air into the engine as well. If you don't have any adjustment on the secondary blades you might end up needing holes bigger than 2mm with a big cam. If so start drilling the secondary blades as well.
When you have this right you should be able to get the throttle blades closed enough to loose the vacuum at the port and still have it idling at the correct rpm.
Next you need to plug the vacuum port (don't connect the dizzy yet) and place your vacuum gauge on a port from below the throttle blades (manifold vacuum).
Check that the rating of the power enrichment valve (holley) or enrichment springs (Carter/Edelbrock) is two inches below this level.
It may help to connect a long hose to this port so that the gauge can be read while driving later.
Now leave the vacuum advance disabled on the dizzy and also disable the secondary actuation on your carb if it is a 4bbl. Remove the linkage if it is mechanical or plug the vacuum pipe if it has vacuum secondaries. Wire the secondaries shut to make sure.
Go for a drive.
If you have a rich/lean indicator check that the mixture is maintained at all times.
If you get a momentary lean condition when you open the throttle quickly you need more accelerator pump shot by installing a bigger nozzle. If the duration of the shot is too short (it was ok initialy but then went lean for a short time) you need to change the little plastic cam that operates the pump on a Holley or use a different lever hole on a Carter.
If the carb runs lean at a constant highway speed a larger primary jet is needed. If it is constantly rich go to a smaller jet.
If it is OK at light throttle speeds but rich at high speed have a look at the vacuum gauge again while it is happening to see if levels are dropping below the valve opening point.
It is important that after making any changes at all you check the idle fuel level again.
When you are happy with all the above reconnect your vacuum advance on your dizzy and make sure the timing curve is ok on your engine with no knocking and the like.
Then check once more that the mixture is right at idle and you have no vacuum at the spark port and that it drives well on the primaries with no lean or rich spots and the fuel level is ok.
Everything ok?
Next step.
Now we re-connect the secondaries and go for a drive again.
Again check to see if the mixture remains stable at all times. If it goes rich at high engine speeds (drive some distance in second gear to simulate high speed without breaking the law) and check the vacuum reading again to ensure the power valve remains closed at normal cruise.
If it goes rich or lean at high speeds now it could be because the secondary jets need changing but this should be rare.
The main problem with secondaries is they can cause a bog when opened quickly.
The fix depends on the type of carb you have.
A Carter/Edelbrock AVS or TQ allows you to loosen the air door tension until the car bogs. Then re-tighten about a 1/4 turn and test again. Aim for the fastest opening without a bog.
Some Carter and Edelbrock AFB carbs have a counterweighted secondary velocity valve door (what a mouthfull!) that you have to trim mass from or add mass too in order to trim the opening rate.
Holleys are either vacuum secondary or mechanical secondary 'double pumper'.
The opening rate of the vacuum secondary is done by swapping in lighter diaphram springs until you get a bog and then go back a spring.
With the double pumper you need a huge shot of fuel if the pedal is mashed open. This is achieved by changing the nozzle size and or pump cam.
