I just took the cam out of the 70 Challenger R/t I just bought , one lobe is round and the lifter is dished.What would cause this to happen? Should I look at the valve for sticking or a broken spring?The push rod looks ok.The cam is a Crane CCH 302-2.The car was a bracket racer that I`m putting back on the street. Thanks.
I know from experience that an oil filter does NOT catch the metal from a failed cam. Your bearings and oil pump have suffered from eating this metal and should be replaced. The engine ideally should be completely dissassembled and cleaned. You can also just stick in another cam and lifters and Keep your fingers crossed. Depends on how radical the engine is and what you're willing to risk in the future.
