WIth "open" chamber heads to calculate your "total combustion chamber."
Gasket height + deck height + Combustion Chamber = Total Combustion Chamber.
for my engine:
Gasket Volume = 4.56 CC
Deck Volume = 27.14 CC
Head Chambers = 81.5 CC
Total Combustion Chamber = 113.2 CC
Using Desktop Dyno I got 8.96:1 compression ratio.
Now to my question; if I change my cylinder heads to the edelbrock performer RPM with "CLOSED" combustion chambers would my compression ratio increase?
Here is what I think:
Edelbrock Performer RPM Heads 84 CC
Since they are closed chambers you don't have to add gaket volume and deck height volume, right?
Using desktop Dyno my compression ratio increases to: 11.72:1
Is that correct or does closed chambers not effect total combustion size in that way?
