If you are running rich, check your fuel Pressure!!
One again I am trying to spend as much money as possible for a small fix. I have been running an Edelbrock Thunder AVS series carb (800 cfm) and trying to tune it. It has always run rich, no matter how many different jet combo's and metering rods I have tried.
So genius that I am, I bought a new Holley 4160 Electric Choke 750 with a 4150 conversion so I can use jet's for and aft rather than metering plates. Found a neat chrome dual fuel line with a built in pressure gauge as well. Got the exact specs from Mopar performance for what jetting they recommend for my crate 402/435.
Put it all together, and viola! I have 13 pounds of fuel pressure! Way too much! Bought a $40 pressure regulator, installed it, set to 6 pounds. Now it runs great!
Bet the Edelbrock would have worked with the regulator as well..
Live and learn!
Live and learn!
