by Roger » 20 Aug 2004 1:52
Thanks for the quick replies, suggestions and photo too.
I can see that your set-up sits slightly higher than the fenders Dave and I am not surprised given you have a "raised block" and 3 carb set-up. I'm not sure whether my problem stem from the new engine mounts or what, but others I have spoken to who have made a similar conversion over to a 4bbl from the original set-up on a small block, have said that the standard hood should be fine. I've taken a couple of pics to show you what I mean, then I'll let you experts decide which way would be best for me to go. I've always like the meaner appearance that the r/t style hood gives the car, so will probably opt for this, however I have also liked the wolf in sheep's clothing approach too.
Anyhow - as usual I really appreciate your comments and suggestions. I will look for an air cleaner base with a deeper dish and rebate, so it sits lower, however I am doubtful that even this will solve my dilemma Lars, as the top of the carby sits taller than the fenders, and I havn't even got gasket materials or a spacer under it yet. As you can see, I still have to bolt on the power steering pump, alternator and aircon compressor (lying down on the left and still connected), but am pleased with the work I have done so far. I've learned heaps from this project and can't wait to fire her up. I've decided to keep the original exhaust manifolds to avoid possible dramas with extractors leaking and clearance issues with the starter etc. The rebuild on the power steering box was the only thing that cost the earth here in oz at almost $1000 or about US$700 - a hefty price to pay and in hindsight I would have been better to go with manual steering, however I can always change over at a later date. The trans is next and I have met a fellow on the net who lives not far from me who had a 904 rebuilt, fitted with a "stage 3" shift kit, deep pan sump and is asking only $400 for it complete and unused (he sold the drag car he had it built for). I plan to buy it as a replacement for the original trans I still have which is a little sloppy in the changes, however I'm unsure I need a "stage 3" shift kit (whatever that may be) as I only intend to use my car for cruising and weekend touring with the missus and tin-lids, not racing down the strip.
Well thanks once again for your opinions and advice - it's truly appreciated.
Cheers...Roger
- some bits are just sitting there (carb, air cleaner etc) to get an idea
- can't even see the other fender from here
- see what I mean?
