Hmm....So I have my car running 350HP and 400lb/feet of torque.
What will happen to the performance of the car if I leave the HP the same and find mods that add alot more Torque?
dave-r wrote:I think you are confused? If you increase torque you are increasing horsepower unless you are making your peak torque at much lower rpms.
Read this;
http://challenger.mpoli.fi/phpbb/viewto ... 3936#13936
It should help you to understand.
dave-r wrote:Why do you want to? Do you want to pull a heavy load at slow speed? Did you actually read and understand the link I gave you?
To make low rpm torque you normally fit a camshaft with less duration. This will lower the rpm where you make peak torque. It will also lower your HP and reduce the top speed you can run.
Making your engine bigger (more inches) will increase torque. Put another way. burning more fuel and air increases torque. So anything that makes the engine more efficent will increase torque and HP.
72-318-Edelbrock wrote: Torque at low RPMs = good acceleration, ok bud?
