Starter loosing torque
I have a gradually increasing problem with the starter in my 440 (comp 10.5). When trying to start it cranks to slow. Turns a few times and then slows down and stops. Suspecting the starter is starting to give up. Have checked all cables, grounding and connections. Battery new yellow Optima giving out 925 A cold start current. The thing is that the problem have got gradually worse over time. Can a starter die slowly? I thought it would either be working fine or not at all. If it can die slowly what happens with it? Anything that can be fixed? What mini-high-torque starter is best buy if I have to replace? Thanks in advance for any info. / Lars
