I am having trouble with my fuel system. I recently tried to start my engine with no success. I have a clear fuel filter so I was able to see that no fuel was running up to the carb. I replaced the fuel pump because like most people, I assume something is broken without testing it. This didne help. Knowing that sometimes wou have to run the engine at greater than a cranking speed to get it to prime, I manually filled the carb with fuel and it started fine. I ran it at about 2k rpm and for about 1 minute but the carb ran out of fuel and the engine died. There was no pumpimg. Thinking that there might be a clog in the line, I tried blowing into the fuel line in a reverse manner. I could hear gas bubbleing in the tank. I got a pretty good buzz blowing hard into that fuel line so it wasn't a total loss.
So where does this leave me? I am fearful that I have flattened the lobe on the cam which actuates the fuel pump push rod.
Any suggestions?
Thanks,
Perry
oh yeah, it's a 440 if that matters
