SO hear it goes... Magnum heads onto a LA block (360 MP shortblock 9.5:1 CR). Thoughts/Opinions?
Pros:
Closed chamber style, better quench effect, ups the CR.
Swirl port effect.
Better exhaust scavenging.
Stock 1.6 rocker ratio.
Plentiful (and hopefully cheap) in any junkyard: 92-02 V8 (5.2 and 5.9) ram, dakota, or durango.
Supposedly flows better than earlier production heads (non-mags).
Cons:
Intake manifold selection, or lack their of. Could use a non-mag one, but this would necessitate drilling new bolt holes due to the difference in intake bolt angles.
Valvtrain oiling considerations. Not a biggie, all the parts are out there, hydraulic (non-mag) or roller-hydraulic cams seem to be the only options with out major customing/fabbing.
Rockers are pedestal mounted instead of shaft mounted.
BTW magnum R/T heads are aftermarket only right? I mean they didn't come on any production vehicle?
Well there it is fellas. Post away please
