I know Dave, I foul myself also sometimes with the output of the hemi. I guess this year I'll run 'only' high 11's while finetuning the car. Also I'll only launch it at idle as I still have the 8.3/4, till the dana comes in it's not a pleasant idea to launch at 4000 it seems to me. As for the putting it together, this should be no problem. It will be shipped in coming march.
But then again, an electric fuel pump, bigger fuel lines, electric fan, oil accumulator, battery relocation kit, billet rear end caps, safety loop etc. have to be installed along with the hemi.
Some specs it will have;
- 10.5:1 CR
- RBRE H-beam rods
- Custom solid cam; 283@050, .680 lift (how will it sound
- Barton intake (this one looks cruell!)
- 1150CFM dominator
- Ported & polished alu heads
- HV oil & fuel pump
- Swinging oil pickup
- 2.1/8" Hooker Super Comp headers
- 3.5" exhaust w/ 3" flowmasters
- 727 tranny w/ manual valve body and t-brake
- 4800 rpm flash
- 430 gear ratio
- Built to shift @ around 7-7.5k
So this year I expect (if it stays together dave) high 11's while the next season high 10's. According to the pro's (Barton & friends) it should run easy 10's but seeing is believing! But then again, only the looks of the intake / valve covers are worth 2/10's
