Dave,
Have you had your motor run on a Dyno to measure Hp & Torque? If so, what did your motor generate? I just finished building a different 440 for my Challenger (original motor to sit in the garage) and just finished at the dyno shop and have HP & Toorque readings for both 4bbl intake and 6bbl intake and was wondering how the car will do in the quarter based on those readings. I was informed at the shop to expect mid 11's in the quarter if I can get it to hook-up decent (the big challenge). Here are the peak HP & Torque readings - What do you think?
4bbl 560 lbs torque at 4100 rpm
517 HP at 5600 rpm
6bbl 556 lbs torque at 4200 rpm
514 HP at 5500 rpm
I am also trying to decide on what gears to run with a 727 automatic transmission, 3:55 are what I am leaning towards since I do spend most of my time on the street.
Any thoughts on either subject would be appreciated
