318 cranks
Postby redelliott » 11 Dec 2003 6:19
hi everyone
is a 340 cast crank stronger than a 318? with all the 318 build ups lately
how much hp can they take?
redelliott
Postby dave-r » 11 Dec 2003 8:54
As you probably know the 340 and 318 cranks are the same and interchange.
However the 340 was always a forged crank. I will have to look up what the 318 crank was but even if it is cast I would not worry about it. A 318 is never going to make more power than the cast crank will take.
318 cranks
Postby redelliott » 11 Dec 2003 16:21
72/73 340's have cast cranks also most 318 except maybee some early heavy trucks. i guess my question is will a 318 cast crank hold up in a 340 build around 400hp / 310hp at the wheels?
thanks
redelliott
Postby dave-r » 11 Dec 2003 18:50
I beg your pardon Sir! You are right.
Yes now I look in a book I see the 340 crank was forged up to 1972 and cast from 1973 although I bet there was some overlap on the dates.
I don't know how much power a 318 or 340 cast crank will take but i would bet it is a lot more than 400hp. More like 500-600 I would guess.
RPMs are the limiting factor. If you want an engine that makes its power at 6000-8000 rpm you need to look at a better (lighter) crank and con rod.
318 cranks
Postby redelliott » 12 Dec 2003 5:23
thanks for your reply. i never considerd high rpm as a factor
redelliott
cranks
Postby 117 » 18 Dec 2003 0:12
When I redid my 73 3forty Direct Connection recomended shot peening my cast crank. Since the motor did'nt have a lot of miles, and I was'nt planning for a lot more horsepower, I decided to not turn the crank of shot peen it. Shot peening may be an option for you though.
117
