Hello.
I have a 1970 Challenger R/T that was bulit with a 440.
I have known that the engine that it has now wasn't the one from the factory, but I thought it was pretty much like the original.
But now I have looked at some numbers and I an a bit konfused.
The engine is a 440, with heads with the numbers 4006452, witch means that they are 76-78 heads.
The intake has the numbers 05110 3830733 +28, and I have found nothing that mtach that.
Now I have found out that the casting numbers on the block 4006630-440-7, is the numbers on blocks from 1978.
The block allsow has the numbers and letters
8 440 EHP in front of the intake manifold, or valley-cover.
My book says that EHP stand for cast crankshaft,standard 4bbl, and premium fuel recomended.
HP can allsow stand for high preformance (but that is not likly on a 78 eh ??)
Now, the engine does not have a identification plate (the one thats supose to be on the passenger side, just above the oilpan.)
But the transmission has numbers on it.
The transmission numbers are PK4028871 6114 8922
Now I wonder is the vehicle ID plate supose to be these numbers (cause if they are they dont' make much sense)
and what I can understand from these are that:
 P stands for Plymouth Fury,
 K stands for Priceclass Police,
 40 is supose to stand for Body type, but here I cant find a match (the closest are 41; 4-door sedan),
 2; Here there is supose to be a letter for engine ???,
 8 (Model year) this stands for 78 and is the reason i think the engine and transmission came in my car as one,
 8 (assembly plant is either letters or numbers number 8 stands for export.
 the rest i dont have any idea...
Wath do you think of this mess tst
		 by DE » 14 Aug 2001 15:05
