Hi
I have new problems with my car. Now it is overheating. At the beginning of summer and even in spring engine temperature raised up. I have checked the viscotic fan, thermostat, radiator and then I have found exhaust gases in radiator. I have done overhaul of the top of the engine (new Fel Pro gaskets, machining of heads) and after engine start overheating is still existing. I have checked again the radiator and radiator core is only 0.8 inch thick. I know that in B and RB engines radiator should be at least 1 1”.
Could it be a reason for this problem?
I took off the thermostat and I put “solid” fan and I also “boiled” the engine.
Thanks in advance
Jarek
