				440 overheating
08 Aug 2001 11:07by jarek
				Hi
I have new problems with my car. Now it is overheating. At the beginning of summer and even in spring engine temperature raised up. I have checked the viscotic fan, thermostat, radiator and then I have found exhaust gases in radiator. I have done overhaul of the top of the engine (new Fel Pro gaskets, machining of heads) and after engine start overheating is still existing. I have checked again the radiator and radiator core is only 0.8 inch thick. I know that in B and RB engines radiator should be at least 1 1”.
Could it be a reason for this problem?
 I took off the thermostat and I put “solid” fan and I also “boiled” the engine.
Thanks in advance
Jarek
				440 overheating
08 Aug 2001 12:09by jarek
				Sorry, but there is mistake in my message.
Should be "B and RB engines radiator should be at least 1 and 1/4""
Jarek
				440 overheating
08 Aug 2001 17:37by alex
				If you got hydrocarbons in the exaust ya got a leak, head gaskets or cracked head(s) hope it aint too serious
				440 overheating
08 Aug 2001 17:53by dave-r
				Jarek;
The actual core of a 440 radiator is about 25"x17.5"x1.5" or about twice as thick as the radiator you have. That could well be your problem.
Alex;
Not sure what you mean. Hydrocarbons are always present in exhaust gasses.
				440 overheating
08 Aug 2001 20:28by Alex
				Oooooooops, Iment if ya got hydro's in the coolent ya got problems, sorry.
Anyhow I am going off line till after the Nats, I hope you and Linda have a safe journey down and I will see ya there, look for the Rustang with the model carz all around it, oh, I will also have me Chopper out too!!
				440 overheating
09 Aug 2001 6:54by Lars
				I think Alex is right. Probably you have a crack in the head(s). These can be very difficult to see. Look in the radiator while winding engine up and down from high to low rpm and vice versa. If you get more bubbles at high rpm you can be sure you have a leak. Most likely in the head(s). if so I suggest you take the heads to some headoverhaul xpert. Good luck!
				440 overheating
09 Aug 2001 10:06by Joel
				Wouldn't you buy a new head(s) intsead repairing the old ones? I never heard of repairing a cracked block, so why would you have your cracked heads repaired, are they not both cast parts? Mechanics and machinists alike would agree to having the head replaced.
				440 overheating
09 Aug 2001 14:26by dave-r
				One of my heads has been repaired.
				440 overheating
09 Aug 2001 23:48by Joel
				Did it have any MAJOR cracks?
				440 overheating
10 Aug 2001 9:04by dave-r
				Some big block heads have a weakness just above the center exhaust ports. The heads I had ported were cracked here (not my original heads) but a good head shop will repair a head very well. The only worry is that sometimes if the engine is overheated it could stress the repair and allow it to fail. Depends a lot where the crack is though.
Some cracks would cost so much to repair that it is cheaper to get another second hand head.
				440 overheating
11 Aug 2001 2:38by Joel
				That was the point that I was trying to get at originally. You mentioned earlier Dave that there were other mods that you could do than just swirl porting and polishing, something about a three angle something or another.
				440 overheating
25 Aug 2001 20:25by Jarek
				Hi,
I've just changed the radiator. I've put radiator with 2-inch core and everything is ok.
I am again on the road....
Jarek
				440 overheating
27 Aug 2001 20:11by dave-r
				Hi Joel.
I've been away. What were you asking about? Oh three angle valve jobs. That is just a way to get better flow into the cylinder. You will read all about it when you get that book on building small blocks that I keep telling you to get.
  Glad you got sorted Jarek.
