My Challenger is sick. Sorta.
It is having a problem turning over when starting. It acts like a low
battery but the batter checks out fine. Running a red top Optima, in the
trunk.
The hot line running to the engine is welders cable "0". The ground is 4
gage tied to a bare spot in the trunk.
The engine is grounded up front via a 19" 4 gage line running from the block
to the body. All connections have been checked.
The wires to the starter look fine. Good connections.
All connections have been checked and double checked. all lines are new.
The sympoms is first start, no hesitation. The second has a slight pause and
then turns over fine. The third or fourth requires the key to stay on, and
after a couple of seconds, it will turn over fine after one "rrrump". After
that, it will not start
The Alternator it putting out fine. And it does not matter if all those
starts are with in a few minutes or a few hours.
The only way to correct this is to thro the battery charger on to bring the
battery charge up top.
I have never had a starter do this or a starter solenoid, but that is what I
suppect now. It is not a pretty thing to replace. The headers wrap all
around it. I almost think that the headers will have to come off to replace
it.
Whatchathink?
Oh, when it does turn over, it starts in a snap.
