Nice one Tony.
 Glenn. A good set of heads and matching cam on a well built short block with good compression and light pistons can give you up to 150hp on a small block and 200hp on a big block before getting completely unstreetable. That is just a generalisation of course and just my opinion.
You will have to forgive Andy because he lives in the big money 9 second 'street' car world where bigger and more expensive always means better. I have had arguments with him in the past about heads. He equates big flowing ports you can get your fist into with power. Which is true if you live in a 7000rpm 9 second world. He forgets that real people drive these cars on the street 99% of the time where high velocity in the ports is key to making power and torque at 'street' rpms. It is easy to make a port flow big numbers by making it larger. Making it flow fast with a higher velocity and smaller port is the hard thing and that is what us guys that drive our cars need.
But don't get the wrong idea about Andy. He is a very big hearted soul that goes out of his way to help other Mopar owners. He lives in upstate NY and has single handedly helped many mopar owners over here in England get the parts and even cars they want. All without making a penny from it himself!
It is just that he is originally from Birmingham so he has a handycap compared to the rest of us!
  Oh and petrol costs $5.00 a US gallon in England.
Roger. Some engine builders use double valve springs (one inside the other) as a way to increase the valve seat pressure to keep the lifter on the cam with wilder cam profiles. Some valve springs look like a double spring but the inner one is just a 'damper' that works with the outer spring.
There is no need for double springs these days on a street car.
