 by Joel Bennett (Joel) » 08 May 2003 10:20
			Production of the 383 began in 1959. The 383 started off as an RB, (Raised Block). It had a bore of 4.03", dual-quads and put out 345hp @5000rpm and 420ft lbs @3600rpm.
In 1960 the the most powerful 383 that year came with the famous 300J heads and inline dual quads, which produced 343hp @5000rpm, but this engine is very rare. The 2bbl that year had a compression ratio of 10.0:1 and put out 305hp @4600rpm and 410lbs @2400rpm.
In 1963 There were three high performance versions. THe first had a single 4bbl with 10.0:1 and had 330hp @4800rpm and 425ft lbs. @2800rpm. The second most powerful version had 10.10:1 a single 4bbl carb and put 360hp @4800 and had 470ft lbs @3200rpm. The top-of-the-line 383 for 1963 came equiped with dual quads, but had a lower compression ratio, 9.60:1, but it put out 390hp @4800rpm and 485ft bls @3600. The 2bbl 383 that year put out 305hp. 1963 was the 383's penical and nothing but lower power outputs were to follow.
In 1964 the power output was lowered so as not embarrass the hp ratings of the larger engines. A only 1 4bbl 383 was offered. This engine had 10.0:1 compression and had 330hp @4600rpm and 425ft lbs @2800. THe performance remained through '65.
In 1966 the 383's performace dropped a bit. The 383 in '66 had 325hp @4800rpm and 425ft lbs @2800rpm and 10.0:1 compression. The output remaind through '67.
In 1968 the 383 got a boost in power, however the 2bbl's power dimminshed. The Super Commando 303 had 330hp @5000 and 425ft lbs. @3200rpm, 10.0:1 compression, an unsilenced air cleaner and dual exhaust. Also in '68 a special edition 383 was developed exclusively for the RoadRunner and the Coronet SuperBee. This 383's power was bumped up by adding high performance parts designed for the 440 in the GTX and the Coronet R/T, introduced in '67. The new parts included redesigned heads, larger exhaust valaves, (1.60" to 1.74"), recontoured ports, and heavy duty valve springs and rocker arms. This 383 also used high performance cam from the 440 was also used. A new dual-plane intake manifold was used, with a Carter AVS 4bbl carb on top. THe air cleaner was also unsilenced and the engine was also given dual exhaust. The power rating for the engine was deliberatey under rated, kinda like the Hemi was. This awsome 383 had a supposedly power rating of 335hp @5200rpm and 425ft lbs @3400. The engine stayed the same for '69.
In 1970 there were three versions of the 383 and all three had their compression ratios dropped. The 2bbl dropped to 8.7:1 so it could run on regular gas, but its horsepower ratiing stayed the same at 290hp. The two high performance versions had their compression dropped to 9.5:1, but their h.p. and torque ratings stayed the same. The 335h.p. 383 also switched to a Holley 4bbl Carburetor in '70. In '71 the high-performance 383 was detuned. Both the 2bbl and the 4bbl 383's compression ratios were dropped to 8.5:1 to be able to run on regular gas. The 2bbl had 270hp @4400 and 375ft lbs @2800rpm. The 4bbl had 300hp @4800rpm and 410ft lbs @3400rpm.
In 1971 Chrysler stopped prodcution of the 383 and began the production of the 400 in '72, to take the 383's place, which it did poorly.
