 by John P (Blue) » 12 Dec 2002 18:43
			Nick ,the 360 flywheel is different to the 340, physically they are the same diamensions, but the 360 'wheel has weight taken out of it as the engine is externally balanced, as opposed to the 340 which is internally balanced. you can check which one you have by removing the bottom tray on the bellhousing and look at the back of the flywheel ( the side faceing the engine) turn the engine over by hand and look for some large circular blind holes, if you have them it's a 360 flywheel, if not it's a 340.
