I am needing help in determineing the best course of action for my engine(s). I have two, a 72 318 and a 73 318 w/ electronic ignition.
The 72 is original to the challenger and has been in dry storage for around 18 years.
The 73 is original to a coronet which sat outside a number of years.
I need several opinions on several subjects:
1. Which engine should I use.
2. How do I boost the horsepower of these "neutered" engines. I would like a more than 200 but less than 300 as I have a 904 trans. This car will never see the track but would like more than the current 150 they produce.
Do I need a new crankshaft, camshaft, carb, piston, heads? If you could recommend some specifics as I have no experience in rebuilding engines, that would be great!
3. Also, can I disconnect all the emission stuff, and would that make a difference?
Thanks guys
		 by Clint Beccue (Clintb) » 18 Oct 2002 14:18
