by Jeff Maxwell (Redchalleng » 22 Sep 2002 1:11
First of all, OK so bad things happen sometimes. Look at what's good. You've got a car with a big block and you're 17. What a great start! Don't give up on school, as you'll use some of that stuff later, so dig in and hang on.
Point two, get a better job to improve what you're making (as long as it doesn't interfer with school). With your background already, you can probably improve dramatically by looking for a job using your car skills. Some small shop could use an intern, or even a new car dealer could use a lot kid with other duties. Depending on the situation, some dealers could even pay for an education for you to be a tech. Then, use the place where you work as a springboard to fix your car as you like. You'll be around other guys who will want to help you accomplish your goals!
Point three, you aren't the first or last this kind of stuff happens to. My cousin did the same thing in 1974 to his '68 Road Runner. He ended up swapping around and ended up better.
Sorry it happened, but it potentially could be the best thing that happened based on what could come from this! All this from what you would consider an old fart, as I was just a little older than you when your car was new!
And, as Dave said, writing in caps is LIKE SHOUTING. Bad form.
