 by Alex (Alex) » 11 Sep 2002 16:12
			For my two pence worth I think Dave is correct in everything he has said.
I have worked with multi turbo'd engines for years and it is not easy to do, there is the problem of phasing the turbos, so they come in and go out at exactly the samr time, this is not easy, you may think that two turbo's of the same design work the same, they won't, setting up the waste gates is a drama, how are you going to modulate the boost? what management system are you going to use? you need a method of increasing the fuel relitive to boost pressure, usually using a m.a.p. sensor. using several turbo's is a great way of bringing the boost in early, as you can use small turbo's that react far faster hence less lag, there is a guy over here who has a Viper running twin turbo's already and I believe Hennesey has gone the turbo route as well, but 2K h.p.?? I doubt it, both the cars mentioned make around 800 r.w.h.p.,you can bolt 10 turbos on, but they will still produce the same boost as one, the turbo will make as much boost as it can flow, 1 turbo can make upwards of 30 p.s.i. on it's own, but no engine will take it, the best you can really hope for with a full prepped engine, and I mean O ringed block, the works is gonna be 20 or so p.s.i., and then you have to consider the heads, they wont be able to move this much air, you will have to have a custom cam etc and a programmable e.c.u. someone who knows how to dial it in and around 200 hours on the dyno to get it right, about which time, it will be ready to be re-built and start again.
I used to work on cars like this all the time and ran a dyno, I saw so many dropped faces of guys who hadf spent thousands on engines like this that were "guaranteed" to work and gave terrible results!
Go with Barton, his work is awesome, I have seen and worked on motors he has built and they are quite simply the finest engines on the planet, the workmanship and attention to detail far outways the cost, and they will last, tell them what you want and they will build the motor to your specs and give you a true dyno figure at the end
Sorry about the spelling etc, but I feel like s*#t
