There is one article in Mopar muscle that I would like to share with you, HP-lovers! It is a test between 11 different intakes on a brute 440-engine!
All intakes were single four-barrel 4150-flanged designs; and all, with one exception, were run out-of-the box stock. They used a high-powered engine to do the test, that really pulled the air. Their objective was to test for higher rpm power.
Test engine:
-.060 inch over production 440
-Arias forged 12.5:1 domed pistons
-Production #915 heads with seriously reworked ports
-Manley 2.25 inch intake valves and 1.81-inch exhausts
-Comp roller cam with 260/258 at .050 and over .650-inch lift with Comps 1.6:1 roller rockers.
-Race Demon carburator 950AD
Here are the results from the dyno:
Intake: Chrysler Factory ’70-’71 #2951736
Type: Two-plane
Rated rpm range: N/A
Max hp: 575.4@6200rpm
Max Torque: 581.2@4000rpm
Avg. Hp 4000-6600 rpm: 534.3 hp
Avg.Tq 4000-6600rpm: 535.1 lb-ft
Intake: Edelbrock CH4B #2290
Type: Two-plane
Rated rpm range: 1500-5500
Max hp: 607@6400rpm
Max Torque: 573.7@4000rpm
Avg. Hp 4000-6600 rpm: 544.6 hp
Avg.Tq 4000-6600rpm: 543.5 lb-ft
Intake: Weiand Action+/Holley #8009
Type: Two-plane
Rated rpm range: Idle-6000
Max hp: 597.2@6300/6400rpm
Max Torque: 564@4000rpm
Avg. Hp 4000-6600 rpm: 536.9 hp
Avg.Tq 4000-6600rpm: 535.7lb-ft
Intake: Edelbrock Performer RPM #7193
Type: Two-plane
Rated rpm range: 1500-6500
Max hp: 610.2@6100rpm
Max Torque: 590.2@4000rpm
Avg. Hp 4000-6600 rpm: 555.9 hp
Avg.Tq 4000-6600rpm: 555.4 lb-ft
Intake: Holley street dominator 300-14 (Not stock, mildly modified!)
Type: Single-plane
Rated rpm range: Idle-4800
Max hp: 636.0@6200m
Max Torque: 598.2@5000rpm
Avg. Hp 4000-6600 rpm: 572.5 hp
Avg.Tq 4000-6600rpm: 571.1 lb-ft
Intake: Edelbrock torker (Original) #3015
Type: Single-plane
Rated rpm range: 2500-6000
Max hp: 605.8@5500m
Max Torque: 608.4@4700rpm
Avg. Hp 4000-6600 rpm: 564.6 hp
Avg.Tq 4000-6600rpm: 565.5 lb-ft
Intake: Edelbrock torker II #5091
Type: Single-plane
Rated rpm range: 2500-6500
Max hp: 627.8@6300m
Max Torque: 593.3@4900rpm
Avg. Hp 4000-6600 rpm: 565 hp
Avg.Tq 4000-6600rpm: 563.3lb-ft
Intake: Edelbrock TM-7 #5415
Type: Single-plane
Rated rpm range: 3500-7500
Max hp: 618.3@6200m
Max Torque: 601.7@4900rpm
Avg. Hp 4000-6600 rpm: 568.5 hp
Avg.Tq 4000-6600rpm: 568.1lb-ft
Intake: Edelbrock Victor 440
Type: Single-plane
Max hp: 637.7@6400m
Max Torque: 593.0@4700rpm
Avg. Hp 4000-6600 rpm: 568.1 hp
Avg.Tq 4000-6600rpm: 570.1lb-ft
Intake: Weiand Team G/Holley #7534 (Bad casting!)
Type: Single-plane
Rated rpm range: 3000-7800
Max hp: 597.2@6300m
Max Torque: 569@4900rpm
Avg. Hp 4000-6600 rpm: 540.3 hp
Avg.Tq 4000-6600rpm: 534.3lb-ft
Intake: Mopar Performance M-1
Type: Single-plane
Max hp: 628.9@6100m
Max Torque: 589.3@4900rpm
Avg. Hp 4000-6600 rpm: 563.7 hp
Avg.Tq 4000-6600rpm: 566.9lb-ft
I am a bit surprised that the factory #736 casting is able to crank out 575 hp.
Any other comments?
		 by Christer (Christer) » 10 Jun 2002 10:01
