HELLO
ID LIKE TO FIND OUT WHAT SOME ONE ELSE HAS DONE TO MAKE IT RUN EFFICENTLY.BEING THAT I MIGHT HAVE TO PULL THE MOTOR OUT AGAIN.
IM RUNNING 69 SETUP,SPEED-PRO 6PK 2355/.30 OVER FORGED PISTONS,PLASMA RINGS,284/471 PURPLECAM 110 CL,STOCK RODS,SHOOTPEENED & POLISHED,WINDAGE TRAY,PORTED & POLISHED 906 HEADS,CRANE RETAINERS & SPRINGS,ADJ. ROCKERS,STOCK VALVES,6QT PAN,MAGNUM EXHAUST MANIFOLDS,MP ELECTRONIC IGN,AUTO WITH 3.55'S WITH A/C & PWR BRAKES.(YES I WANT THE BEST OF BOTH WORLDS,WHY NOT I DRIVE A MOPAR)IM RUNNING 14 DEGREES INITIAL TIMING DEPENDING ON FUEL IM RUNNING.
WHAT IS THE BEST CAM AND OR CENTERLINE FOR THIS APPLICATION?HOW ABOUT ADJUSTING FRT/R CARBS FOR BETTER FUEL MIXTURE @IDLE.,PWR VALVES,CARB. METERING PLATES,ACCEL LINKAGE CAMS,DIFFERENT RATE VAC. SPRINGS OR JUST LEAVE IT STOCK.I DID NOTICE LOWEND PWR LOSS
WHEN I PULLED OFF MY CH4B,780 DP.
ANYONE HAD PROBLEMS WITH PAINT BURNING OFF THE SIDE OF THE VALVE COVERS WITH STOCK MANIFOLDS?
OH BY THE WAY I GET 2300 SERIES CARB KITS FOR ABOUT 15 BUCKS,NO VAC DIAPHRAMS BUT I DONT CHANGE EVERY TIME I GO THRU THE CARBS.
ANY INPUT OR IDEAS WOULD BE APPRECIATED
THANKS IN ADVANCE GIL
