 by Jarek Szepietowski (Yaro) » 19 Jul 2002 9:49
			I installed new pistons (Keith Black 237 – flat top) and they were taller than the deck height at TDC (about 0.07”). The originals were level. There was some interference with the head so I ground the head a bit to eliminate it. The heads are 452's from 1977. There were no any collision between pistons and heads (I checked it many times) Anyway, I buttoned her up and now the motor runs with a hell of a loud, rapid, metal on metal clanging sound.
I do not thing that is piston slap because this noises are ”too gentle”.
Finally, when you turn the engine off the motor is making “knock-knock, tuk, tuk”, like we were making popcorn for a couple of minutes then dies down.
It is not a engine run on.
For that matter, you only have to crank the motor a few second cold and you hear that strange noises. I have checked lifters preload and it is set according to spec.
So that's the story. Actually the car runs fine with an even rhythmic pulse from the tailpipe so valves aren’t getting bent. It just makes a hell of a racket. Anyone experience this after similar engine work?? I swear there's no contact pistons with the head. I also swear I double checked everything so nothing was left loose.
Should the pistons be above deck height?
Why lifters is making “knock-knock”?
Jarek
