 by Douglas Little (Dlittle) » 27 Nov 2002 12:44
			I just bought 340 engine dissembled. I have 10.5 pistons, steel crank, x head, windage tray, etc. The rods are from a 360. It appears that the pin in the piston of the 340 locked in the piston and floated in the rod. In the 360 the pin floated in the piston and locked in the rod. I trust the man I got the motor from. This is not the first motor I have bought from him and he has a lot of mopar experience. He said that the 360 rods will work on the 340 pistons but I worry that they may not hold up as the pins will want to be stiff in the piston and the are no oil holes in the 340 as on the 360 piston to lub the pin as it floats. Can someone advise me on this. I want to get the motor built but not by starting out with doubts.
