dave-r wrote:Best to have the valve on the drivers side and the breather on the passenger side. Otherwise at high rpm you can get oil in the breather.
Pat wrote:It is more likely that they moved the breather to the passenge side valve cover to easy be abel to rout the emisson system for the cars that needed that ! If the Engine breaths out thru the breather in a pcv system when the engine is up and runing there should be a fault eaiter on the pcv valve or the engine has to mutch cylinder leak or a realy poor vacume. The acual point of the pcv system is to never have any presiure inside the engine and a breather whit filter material inside is whats needed in those systems.
But ho am i to know when i drive a Challenger
dave-r wrote:Pat wrote:It is more likely that they moved the breather to the passenge side valve cover to easy be abel to rout the emisson system for the cars that needed that ! If the Engine breaths out thru the breather in a pcv system when the engine is up and runing there should be a fault eaiter on the pcv valve or the engine has to mutch cylinder leak or a realy poor vacume. The acual point of the pcv system is to never have any presiure inside the engine and a breather whit filter material inside is whats needed in those systems.
I remembered now why it was. It wasn't oil coming out of the breather. It was because the crank throws a lot of oil up into that right head. If you have the valve on that side it sucks it up and your engine gets to burn it.
The left side head does not have as much oil splashing about up there. So they moved the valve to that side.
That's what it was.
So yes it does matter which side if you want to burn less oil.
cv70chall wrote:So,
Final Verdict..
Place the breather on the passenger side
Place the PCV on the driver's side...AND install a 1" piece of screen directly below the PCV intake.
Yes?
Pat wrote:For more practikal resone yes plase the breather on the rear of the passenger side valve cover and
the pcv on the driverside rear valve cover.
cv70chall wrote:oh wise one...
dave-r wrote:Push all you want while you can because from the 1st March this board is history.
dave-r wrote:Pat wrote:For more practikal resone yes plase the breather on the rear of the passenger side valve cover and
Which is exactly what I suggested....
dave-r wrote:Alright Pat. Don't have a stroke.![]()
It was something that came up once years ago. So long ago I don't remember correctly. But Chrysler changed it for a reason. It was much easier the other way around. But they changed it anyway for the 1969 model year and I seem to remember reading about it back in the 90s. If it didn't matter what side they used why change it?
I read about it somewhere. When I say I didn't make it up I mean it was in a tech manual or something. I just don't remember where.
