by cv70chall » 22 Oct 2015 11:35
Mine look to be "un-milled". Still just horrifically close to the VC.
Anyway, I removed the cover and found that- once again- the gasket had been "pushed" inward away from the valve cover in the middle area and near the front lower stud area.
I picked up a tube of Permatex Copper this time and snagged a set of rubber coated fiber gaskets.
After some light work at the wheel to get them to fit snuggly into the cover, I did a test fit onto the head with just the gasket- and found that- due to the angle of the head (normal) and closeness of the heat shield on the exhaust gasket, when you set the valve cover gasket down, it actually hits the center 3 springs and forces the gasket to deform- thus pushing it "upward and outward". You actually have to work it down onto the head, past the springs and heat shield and then it sits fine.
So, I applied permatex to the head rail and then gently fit the valve cover over it and onto the head. This time, the gasket "snapped" into place and it felt like a good solid mating.
Hand tightened the studs and let her sit over night. We shall see this evening when I crank her up and look for leaks.
If this fails, then my only option will be to partially remove the manifold on the right side and replace the gasket.
CVchall70
