Believe it or not, I'm STILL wrestling with the oil leaks on both sides of my engine's valve covers. This next time will be the 7th attempt- and I'm frustrated mainly because this is such a simple thing to do!
What I'm getting to is possibly the exhaust manifold gaskets that I used- specifically the Mopar gaskets with the heat shields on them.
The shields are apparently preventing the valve covers from completely seating on the head rails without the gasket tabs being forced/ bent upwards- thus causing the gasket to "roll" outward or forward away from the inner valve cover railing.
Short of unbolting my HP manifolds and changing out the gaskets- which is a pain in the ass with the engine in the vehicle- I will try to alter the heat shields where the gasket tabs would normally sit- so as to prevent any contact between them and the heat shield in seating the valve cover.
Has anyone experienced this issue- specifically with these exhaust manifold gaskets?
Ugh!
