OK, so I made my fourth attempt to get my passenger side valve cover to seal properly. I've been through the cork, fiber and recently- those expensive Moroso rubber/ steel core gaskets. NO LUCK.
It ALWAYS leaks at the two lower center areas.
RIDICULOUS!
I've even done the following:
1. Test fit the gasket
2. Applied Ultra Grey/ Ultra Black to valve cover, install gasket and touch up top of gasket areas
3. Clamp- let sit for 24 hours
4. Apply sealant to top of head- mainly around the bottom and about 1.5" up both sides
5. Install Valve Cover, hand tighten and let sit 1-2 hours, then tighten to proper specs.
6. Let vehicle sit 24 hours- I let it sit nearly 2 full days before starting it.
7. Re-checked & tightened to re-seat
Fired her up. Nothing for about 10 minutes- then the leak and subsequent smoke from those same two places.
Any ideas?
I'm OK with a drop or two on the floor- heck- EVERY Big Block leaks a bit, but this is nuts!
