There's been a very long time since i visited, sorry for that...
Now, ya'll that still remember´s me do know i sold my beloved Challenger.
Now.... There's still some Mopar mixed blood running in my veins
Short summary:
I just recently swapped one of my harleys in a trade to get a -68 Charger Special R/T 440 4 barrel from factory in St Louis. (Sadly a smog engine in it, dough).
Pic's willl come in time i promise you.
The car misses it's gearbox.
I 've already ordered a restored A727BB prepared for 7-800 hp's... i asked for a shiftkit installed aswell. This is supposed to be B&M parts all the way if i understood it correctly.
Now to the issue:
I got me a #10415 part numbered B&M converter with 2400rpm stall speed....
My friend Roland kindly offered me help to do this job. Before we lift the trans up, i really want to know this will be correctly done from the start.
So my question is:
Assuming the engine bottom is factory standard and stock, nothing changed..... With the stamping H= year 1972 and 5 31= May 31th and the relevant letters HP= high performance.... to the side of the distributor.... I personally asssume the car should, have a forged crank, right? what else should make a smog engine a "high performance"? right? And from researching, it then equals that it then also is internal balanced? That is my friends... my question here... Anybody?
Because i need to know if i have to get a B&M flexplate or if i can use the one i already got....
Summit racing says balanced: YES
JEG's says external balanced engines needs the B&M flexplate.
Rolands quick research in his books of mopar big block engines tells only that cast cranks is externally balanced. Nothing meantioned about forged cranks....
I remember my 340 LA was a "HP" and with that there was forged crank...
Can i assume my HP high performance 440 (RB=1973-1978) but manufactured in MAY 1972, has a internal balanced crank, and that i therefore should not need to change the flexplate?
All answers appreachiated.
I hope you all guys are well!
Best regards
Jim
