 It would be great if i could get them to work properly and prove to some that it is possibel to make a difference in realety and not just have lots of negative opinion´s behind a computer (no offence to any one on this board) but if i fale i can always drop back the vacume once again as i wount sell them.
 mm in the opening area and 0 at the throttel blade opening so the venturi will be more strait like the Holley ! The way im doing this in a spark machine is very time consuming but the venturis will be extremly alike in al 4 corners and way more than a cast carb body as the cast moves around alot when it cools down. The center carbs is bigger than the Holley center and my hope is that that alone will inprove alot but whe will see if this will work or if it will be a sacrifice to the speed gods
 dave-r wrote:You can't go just by size. A smaller opening can flow just as well as a larger one. The air can just flow faster in the restriction which improves signal strength and mixture quality.
The ONLY way to know for sure is to use a flow bench. Any other way is just guesswork.
Adrian Worman wrote:That's turned out to be a big difference in what you measured and what the BG carbs are rated at, but is that cos BG flow test 'wet' and the Holley are tested 'dry'?
Still definitely worth milling off the choke horns tho eh?
Keep at it Pat
 Yes the  squirters hole were badly located for the passenger side ! I will run the center carb whit a bit bigger squirter 35 and the outer carbs will be 32. The main jets out of the box on these carbs are 68 in al of them but that will be to smal on the outer carbs for my stroker so i changed to larger in the outer carbs. Ade if your going to run your stroker whit a six pack stock setup like i have done for 2 year you will have to calulate whit a bigger acc pump on the center carb 50cc and change the squirter to 35-38 zise and larger main jets will also be needed and a set of Pro Max billet main jet blocks for the outer carbs will make your engine smile but i cant say i had any luck whit the center main block that Pro Max sells on my early 440 six pack engine so i stayed whit the stock block on the center carb and it works perfect.
 Il keap you updated whit more pic later if i make any progress. How are you comeing along whit yours ? Id realy like some motivations !!!!!!!!!!!!!!!!!
