by Dave-R (Roppa440) » 31 Mar 2002 17:59
Creating a vacuum leak can do the above but it can also cause the power valve to open, making the carb rich, which increases the rpm, which increases the vacuum, which closes the power valve, which makes the carb go lean, which drops the rpm, which drops the vacuum, which opens the power valve, etc, etc, round and round, causing the rpms to rise and fall in a cycle.
Steve has yet to say what the actual problem or symtoms are with his carb. If he could describe what the problem is or even start to answer some of the questions I have asked we could come up with a solution. Lets hope his new carb works first time.
