Can anybody give me a good indications as to prep of the underside when replace the old rubber bushings for a new polyeurethane kit.
What problems will or should I encounter?
What do I need to be mindful of?
   Oh, and I always slice open my hand(s), at whatever I do, it seems like anymore, so heavy gloves might help.
dave-r wrote:You mean suspension bushings? Which ones are you doing?
Front or rear? Both?
UCA bushings?
LCA?
K-frame?
airfuelEddie wrote:A Big 'Fookin' hammer is nice, A Heavy Duty Air Impact Gun and a powerful compressor,a blowtorch to heat up 'stoobborn' fasteners. Thats how I prep things Wayne!:lol: The right tools like a torsion bar clamp & a long breaker bar with 1/2 inch drive end, upper ball joint driver. To name a few
airfuelEddie wrote:It allows you to remove the torsion bar whithout 'hurting' it. Clamping down on the surface of the bar with a pair of vise grips or any tool that leaves marks or gouges on the steel is a No No. The clamp allows you to hammer on the clamp instead of the torsion bar. The ball joint is screwed into the upper A-Arm. It can be a bitch to remove. The ball joint socket allows you to 'grab' the joints hex flats and you can remove it with the special socket and the Air Gun.
Me ,,photos,,surely you jestRedRaven wrote:airfuelEddie wrote:It allows you to remove the torsion bar whithout 'hurting' it. Clamping down on the surface of the bar with a pair of vise grips or any tool that leaves marks or gouges on the steel is a No No. The clamp allows you to hammer on the clamp instead of the torsion bar. The ball joint is screwed into the upper A-Arm. It can be a bitch to remove. The ball joint socket allows you to 'grab' the joints hex flats and you can remove it with the special socket and the Air Gun.
Some photos would be cool!!
 I do have an article though!  Are you gonna replace the whole 'front end'?
 I just went and greased my R/T's 'joints' with Amsoil Long fiber synthetic Race Grease
RedRaven wrote:Ok thats great I will post a pic of the kit so you can see whats what.
I recognize some of the bushings and where they should go but not all.
Where should I start?
 Bye the way, what happened to the tits Wayne?
