 by burdar » 09 Jun 2009 0:31
			If the rest of the front end is stock...rubber bushings, standard shocks, tires with a tall sidewall...it won't do much for you.  If you upgraded to poly bushings, a good high performance shock, and performance tires, the new bar would be a good idea.
This is of coarse my opinion, but it seams like everything should work in sync with everything else.  Putting that bar on a stock, sloppy system won't do anything for you.
